The following parts were replaced after which a loud knock can be heard when going forward or reverse on full right or left lock after the car has been standing for a while but rarely when driving.
1. Front Shock Absorbers
2. Shock Absorber mounts
3. CV joints
4. Big Lower Arm Bushes
5. Small Lower Arm Bushes
6. Lower ball joints
7. Stabilizer Arm Links
Many thanks.
SPONSORED LINKS
Sunday, December 11th, 2016 AT 1:52 PM
JIS001
MECHANIC
Try to put the vehicle over a pit. Have someone rock the vehicle side to side while you check the sway bar bushings. When they are worn out you will see the sway bar moving up and down and making a thumping noise.
