Air Conditioning problem
2000 Kia Spectra 4 cyl Two Wheel Drive
My air went out I was told it was a fuse. I need to know what fuse I need to replace?
Sunday, June 14th, 2009 AT 6:45 PM
MECHANIC
I don't have the schematic for the fuse box. If you have your owner's manual, it should list it in there. Also, if you check the fuses, you should be able to see which one is bad.
