Front tires wobble
PATRICKA
  • JEEP WRANGLER
I have a 2000 jeep wrangler 4 cylinder manual 5 speed with 33x 12.50x15 A/T tires.
sometimes at various speeds the front tires will start to wobble. If I slow down it will stop. Then I can speed up.
The tires are wearing evenly. More in the middle on both tires.
I was going to replace the axle u joints first. Then, front end alinment, then new tires.
What do you think.
Thanks
Patrick
Sunday, September 30th, 2007 AT 11:58 AM
MERLIN2021
  • 17,251 POSTS
No I think you need to check the Track bar, This is there for that reason, if it's worn you may have other front end parts that need replacing!
Sunday, September 30th, 2007 AT 6:56 PM
