Timing chain and tensioner replacement?
ANONYMOUS
  • 2002 JEEP CHEROKEE
How to install jeep timing chain and tensioner?
Sunday, March 24th, 2013 AT 7:51 PM
Here are the instructions and camshaft and timing chain marks to help you replace the timing chain and camshafts int he diagrams below. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Sunday, March 24th, 2013 AT 8:11 PM
JOHN BAER
V8 four wheel drive automatic 149,000 miles.
I am trying to reassemble this vehicle for a friend and need the timing chain diagram. I did not tear this down and really have very little jeep experience. I have been a tech for ten years with Toyota and GM not real fond of Jeep please be a life saver.
This is a 2002 Jeep Grand Cherokee with a 4.7 v8.
Monday, April 29th, 2019 AT 6:56 PM (Merged)
JNOVACK
  • 723 POSTS
To install:
Using a vise, lightly compress the secondary chain tension-er piston until the piston step is flush with the tension-e body. Using a pin or suitable tool, release ratchet pawl by pulling pawl back against spring force through access hole on side of tension-er. While continuing to hold pawl back, Push ratchet device to approximately 2mm from the tension-er body. Install special tool 8514 lock pin into hole on front of tension-er. Slowly open vise to transfer piston spring force to lock pin.
Position primary chain tension-er over oil pump and insert bolts into lower two holes on tension-er bracket. Tighten bolts to 250 inch lbs. (28 Nm).
WARNING:
Over-tightening the tension-er arm Torx bolt can cause severe damage to the cylinder head. Tighten bolt to specified torque only.
Install right side chain tension-er arm. Apply Mopar Lock N, Seal to Torx bolt, tighten bolt to 150 inch lbs. (17 Nm).
NOTE:
The silver bolts retain the guides to the cylinder heads and the black bolts retain the guides to the engine block.
Install the left side chain guide. Tighten the bolts to 250 inch lbs. (28 Nm).
WARNING:
Over-tightening the tension-er arm can cause severe damage to the cylinder head. Tighten bolt to specified torque only.
Install left side chain tension-er arm. Apply Mopar Lock N, Seal to bolt, tighten bolt to 150 inch lbs. (17 Nm).
Install the right side chain guide. Tighten the bolts to 250 inch lbs. (28 Nm).
Install both secondary chains onto the idler sprocket. Align two plated links on the secondary chains to be visible through the two lower openings on the idler sprocket (4 o'clock and 8 o'clock). Once the secondary timing chains are installed, position special tool 8515 to hold chains in place for installation.
Align primary chain double plated links with the timing mark at 12 o'clock on the idler sprocket. Align the primary chain single plated link with the timing mark at 6 o'clock on the crankshaft sprocket.
Lubricate idler shaft and bushings with clean engine oil.
Install all chains, crankshaft sprocket, and idler sprocket as an assembly. After guiding both secondary chains through the block and cylinder head openings, affix chains with a elastic strap or the equivalent, This will maintain tension on chains to aid in installation.
NOTE:
It will be necessary to slightly rotate camshafts for sprocket installation.
Align left camshaft sprocket "L" dot to plated link on chain.
Align right camshaft sprocket "R" dot to plated link on chain.
WARNING
Remove excess oil from the camshaft sprocket bolt. Failure to do so can result in over torque of bolt resulting in bolt failure
Remove Special Tool 8515, then attach both sprockets to camshafts. Remove excess oil from bolts, then Install sprocket bolts, but do not tighten at this time.
Verify that all plated links are aligned with the marks on all sprockets and the "V8" marks on camshaft sprockets are at the 12 o'clock position.
WARNING
Ensure the plate between the left secondary chain tension-er and block is correctly installed.
Install both secondary chain tension-er. Tighten bolts to 250 inch lbs. (28 Nm).
NOTE
Left and right secondary chain tension-ers are not common.
Before installing idler sprocket bolt, lubricate washer with oil, and tighten idler sprocket assembly retaining bolt to 25 ft. lbs. (34 Nm).
Remove all locking pins from tension-ers. WARNING
After pulling locking pins out of each tension-er, do not manually extend the tension-er(s) ratchet. Doing so will over tension the chains, resulting in noise and/or high timing chain loads.
Using special tool 6958, Spanner with adaptor Pins 8346, tighten left and right. camshaft sprocket bolts to 90 ft. lbs. (122 Nm).
Rotate engine two full revolutions. Verify timing marks are at the following locations:
primary chain idler sprocket dot is at 12 o'clock
primary chain crankshaft sprocket dot is at 6 o'clock
secondary chain camshaft sprockets "V8" marks are at 12 o'clock
Lubricate all three chains with engine oil.
After installing all chains, it is recommended that the idler gear end play be checked. The end play must be within 0.10-0.25mm (0.004-0.010 in.). If not within specification, the idler gear and idler shaft must be replaced.
WARNING
Do not use oil based liquids to clean timing cover or block surfaces. Use only rubbing alcohol, along with plastic or wooden scrapers. Use no wire brushes or abrasive wheels or metal scrapers, or damage to surfaces could result.
Clean timing chain cover and block surface using rubbing alcohol.
WARNING:
The 4.7L can use a special RTV sealer instead of a carrier gasket to seal the timing cover to the engine block, from the factory. For service repairs, Mopar Grey Engine RTV must be used as a substitute, if RTV is present. If the front cover being used has no provisions for the water passage O-rings, then Mopar Grey Engine RTV must be applied around the water passages.
Inspect the water passage O-rings, if equipped for any damage, and replace as necessary.
Apply Mopar Grey Engine RTV sealer to the front cover following the path above, using a 3 to 4mm thick bead.
Install cover. Tighten flange head fasteners in sequence as shown in to 43 ft. lbs. (58 Nm).
Install the A/C compressor and generator.
Install crankshaft damper.
Install accessory drive belt tension-er assembly. Tighten fastener to 40 ft. lbs. (54 Nm).
Install lower radiator hose.
Install both heater hoses.
Install cylinder head covers.
NOTE
Before installing threaded plug in right cylinder head, the plug must be coated with sealant to prevent leaks.
Coat the large threaded access plug with Mopar Thread Sealant with Teflon, then install into the right cylinder head and tighten to 60 ft. lbs. (81 Nm).
Install the oil fill housing.
Install access plug in left cylinder head.
Install power steering pump.
Install radiator fan.
Fill cooling system.
Connect negative cable to battery.
https://www.2carpros.com/forum/automotive_pictures/12900_tc2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_tc1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/52960_0900c1528004332b_1.jpg
Compress and lock the primary chain tensioner"”4.7L engine
https://www.2carpros.com/forum/automotive_pictures/52960_0900c1528004332c_1.jpg
Secondary timing chain tensioner preparation"”4.7L engine
https://www.2carpros.com/forum/automotive_pictures/52960_0900c1528004332d_1.jpg
Timing chain system and alignment marks"”4.7L engine
https://www.2carpros.com/forum/automotive_pictures/52960_0900c15280042375_1.jpg
Camshaft positioning"”4.7L engine
https://www.2carpros.com/forum/automotive_pictures/52960_0900c15280042377_1.jpg
Use the Timing Chain Locking tool to lock the timing chains on the idler gear"”4.7L engine
https://www.2carpros.com/forum/automotive_pictures/52960_0900c1528004332e_1.jpg
Timing chain cover bolt torque sequence"”4.7L engine
https://www.2carpros.com/forum/automotive_pictures/52960_0900c15280042374_1.jpg
Crankshaft timing marks"”4.7L engine
https://www.2carpros.com/forum/automotive_pictures/52960_0900c15280042376_1.jpg
Cylinder head access plug locations"”4.7L engine
I hope this helps
CHARLES_LAMBERTI
Hi
i am doing this on a 3.7 same timing system. The plated links on the
cam chains do not align perfectly with the windows in the idler as shown in picture, but are either slightly higher or lower. I get better alignment when biased lower and would say its like 1/2 a tooth low. From being perfect. Is this normal?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,378 POSTS
As long as the marks are as closes as you can get them you should be okay.
VD1969
  • JEEP CHEROKEE
When should it be replaced?
2001, V-8, 4.7 L, 97,000 miles
Monday, April 29th, 2019 AT 6:57 PM (Merged)
GRICHARDS
  • 57 POSTS
I can't say that there IS a set rule for timing chain replacement, there may be a higher level mechanic out there who can provide more information on this.
If a problem indicates that the timing chain is the cause of a no-start, of course replace it. The most accurate method to determine if it requires replacement is a VISUAL inspection of the chain and sprockets. Check the timing chain for too much slack, and check the teeth on the chain sprockets (2) for deformation, chipping, pitting, or discoloration. There is also a chain tensioner that should be checked for noticable wear. Replace the sprockets as a SET.
I have a 96 inline6 with 140,000 miles on it, runs as solid as a rock. The only things other than regular maintenance items I've had to replace in the last 9 years are a water pump (easy), and a Crankshaft Position Sensor (also reasonably easy). I change the oil/filter every 3 mos. Or sooner if I don't like the "color" of the oil. Preventative Maintenance is a great thing, but timing chain/sprocket may be a bit expensive unless you can afford it/do it yourself. Anyone else out there have an opinion?
