1995 Isuzu Rodeo Question Black Smoke and Power Loss around
CAMPBELLOT
  • 1995 ISUZU RODEO
  • 6 CYL
  • 4WD
  • 112,000 MILES
My 95 Isuzu Rodeo puts out black smoke and loses power when I accelerate to around 50 mph. The check engine light comes on some times, but if I rev up the engine, it will go off and run better.
Any ideas what might be the problem?
Sunday, January 6th, 2008 AT 8:30 PM
FISHERMAN
  • 937 POSTS
Hello !!
your engine its running "to rich"
start retrieving the "codes" and come back with the results to start the troubleshooting!
here`s how:
https://www.2carpros.com/dia/index.htm
Good Luck!
Sunday, January 6th, 2008 AT 8:36 PM
CAMPBELLOT
[quote="fisherman"]
Thanks for your reply, but I looked at the info for getting codes and it seems that the equipment for that is only for 1996 and newer; mine is a 1995. Can I still get the codes?
Sunday, January 6th, 2008 AT 8:50 PM
FISHERMAN
  • 937 POSTS
Hello !
Some vehicles start with the OBD II port on 1995
Check your car if it is equiped with the port
Should be located under the steering wheel.
Let me know if has it.
Sunday, January 6th, 2008 AT 8:59 PM
FISHERMAN
  • 937 POSTS
Hello !
Here is how to retrieve the codes and the codes:
https://www.2carpros.com/forum/automotive_pictures/576_rodeo_95_1.jpg
https://www.2carpros.com/forum/automotive_pictures/576_rodeo_951_1.jpg
https://www.2carpros.com/forum/automotive_pictures/576_rodeo_952_1.jpg
https://www.2carpros.com/forum/automotive_pictures/576_rodeo_953_1.jpg
Let Me know on the codes you get!
good Luck!
Sunday, January 6th, 2008 AT 9:12 PM
