With #3 plug wire disconnected the engine starts and runs. When I connect it - the engine will not start. Spark tester indicated a spark. It has a spark even when tester is not grounded. No indications of damage or carbon tracking on distributor. Changed plug and wire for grins - no change.
SPONSORED LINKS
Friday, March 25th, 2016 AT 3:36 PM
KEN L
MASTER CERTIFIED MECHANIC
It sounds like the ignition coil is grounding the system out when connected, replace the ignition coil and retry, please get back to me so we can continue.
Tuesday, May 4th, 2021 AT 12:38 PM
STUMPEDINPENSACOLA65
MEMBER
1 POST
It was the dist. Cap - fires right up. I cleaned the old cap and it had no visible damage or carbon tracking. I thought I had eliminated that possibility. K.I.S.S. RIGHT?
Best Regards,
Stumpedinpensacola65
SPONSORED LINKS
KEN L
Wow that's great you got it fixed, please use 2Carpros. Com anytime we are glad to help.
