Ignition housing barrel, there are two pins on the ignition that are stuck, how to fix it?
FREISETARA
  • 2009 CHEVROLET EXPRESS
  • 6.0L
  • V8
  • 90,000 MILES
I just replaced my ignition lock cylinder, but there are two pins on the ignition that are stuck. What can I use to clean them and hopefully get them unstuck? I don't have the money to buy anything so is there any household cleaner I can use?
Thursday, September 21st, 2023 AT 8:13 AM
  • 108,407 POSTS
Are you referring to the internal pins in the lock cylinder? If so, try using something like WD40. Spray some in the cylinder and let it sit for a bit. Then, see if you can gently work the key into the lock.
Take a look at step 4 in this link and let me know if it helps:
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
Thursday, September 21st, 2023 AT 8:36 PM
