Engine stops while I'm driving
TALAFHA
  • HONDA CRV
My Honda CR-V 1998 250000 km engine starts regularly, but it stops while I'm ‎driving, I tried to restart it but I failed, after 1/2 to 1 hr it starts as if nothing happened ‎‎, this problem recurrent. I replace the coil, fuel filter and fuel bump, the problem is not ‎solved yet. I asked a technical Pearson he tolled me to replace the crank sensor. Any ‎help on this problem is highly appreciated
Friday, March 17th, 2006 AT 4:39 AM
VANDRAGON
  • 298 POSTS
I would go for the crank position sensor!
Sunday, March 19th, 2006 AT 10:24 AM
BRUCE HUNT
  • 3,754 POSTS
Replace the crank sensor and it is usually behind door number one or the timing belt cover. In case, I would suggest replacing the belt as well. No check engine ligt came on? I would bet you got one and it is a code 8 and 9 when you jumper the ECU connection.
Monday, March 20th, 2006 AT 2:11 PM
