2002 Honda Civic A/C not blowing cold air
CLAY4U
  • 2002 HONDA CIVIC
  • 4 CYL
  • FWD
  • MANUAL
  • 100,000 MILES
When my A/C is turned on its not blowing cold air I tried putting feon in the low side but its full the compressor turns on but not getting any cold air to come out
Wednesday, June 11th, 2008 AT 10:40 PM
  • 31,937 POSTS
Hi there,
The first thing you should do is have the system pressures tested, this will give the tech a good idea as to what is going on, if you have added refrigerant, the system may be over pressurized and the hi pressure switch may be cutting the system out.
Mark (mhpautos)
Monday, September 23rd, 2019 AT 11:40 AM
