HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Civic
Suspension
Ball Joint
SPONSORED LINKS
1998 Honda Civic wheel bearing or ball joint or somthing EL
CHUNKS121
MEMBER
1998 HONDA CIVIC
Drive Train Axles Bearings problem
1998 Honda Civic 4 cyl Front Wheel Drive Automatic
how do I know when my ball joints or wheel bearings are bad?
Friday, January 8th, 2010 AT 3:53 PM
KHLOW2008
MECHANIC
Hi chunks121,
You would need to use a pry bar to test the ball joint for free play to know if they are bad.
Bad wheel bearings would emit a coarse noise while driving and taking curves would enhance the noise depending on which side.
SPONSORED LINKS
Wednesday, January 13th, 2010 AT 1:37 PM
Please
login
or
register
to post a reply.
Related Ball Joint Content
Suspension Issue?
I Have A 1998 Honda Civic Dx Coupe, Everything Seems Fine, On Local Roads, But When I Hit The Highway And Reach 100 Km/h The Steering...
Asked by
rakky
1 ANSWER
7 IMAGES
1998
HONDA CIVIC
GUIDE
Ball Joint
A ball joint is used to act as a universal swivel joint that connects the upper or lower control arms to the spindle which is where the axle bearing and wheel is supported....
2002 Honda Civic Front End Creak
Hi I Have A Creaking Noise In My 2002 Honda Civic Front End. Could It Be The Ball Joints?The Noise Is Intermittent I'm Having A Hard Time...
Asked by
neils2002civic
2002
HONDA CIVIC
Bad Handling Round Bumpy Corners
The Whole Car Seems To Jump Sideways When You Hit A Bump Going Round A Corner (like A Scared Cat). It Also Does Not Seem To Take Potholes...
Asked by
jeremyridler
1 ANSWER
2002
HONDA CIVIC
1998 Honda Civic
Noises Problem 1998 Honda Civic 4 Cyl Front Wheel Drive Automatic Xxxxxx Miles Hi I Have A 98 Honda Civic Si 2 Door Coupe. When Its...
Asked by
98v-tech
1998
HONDA CIVIC
2002 Honda Civic Rear Struts
Do The Rear Struts Have Replaceable Cartridges?
Asked by
boboso78250
1 ANSWER
2002
HONDA CIVIC
VIEW MORE
SPONSORED LINKS
Steering Wheel Shaking
Tie Rod End Replacement
Lower Control Arm Bushing Replacement
Online car repair manuals
