1999 Honda Accord alternator
BOYDO
  • 1999 HONDA ACCORD
  • 6 CYL
  • 219,000 MILES
Battery light came on in car. Change alternator week goes by battery light come on again change alternator again. Check voltage at battery 8amp change battery check voltage 12.2volts start car and check volts 11.9 alternator not working. Change alternator again same problem where is the fuselink on this car
Saturday, June 27th, 2009 AT 5:24 PM
KHLOW2008
  • 41,814 POSTS
Hi boydo,
Here is a wiring circuit diagram and the location of the various fuses.
https://www.2carpros.com/forum/automotive_pictures/192750_Charging99Accord6cyl01a_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_Charging99Accord6cyl01b_1.jpg
Did you test the charging at the alternator main terminal?
Is the charge light showing when engine OFF and ON?
Sunday, July 5th, 2009 AT 9:49 AM
