Hi, It will probably take up to a three to four hours if the person has been aroun cars for awhile .. see the info on your car .
I hope this helps you .
REMOVAL & INSTALLATION
See Figures 1, 2, 3, 4, 5, 6 and 7
CAUTION
The EPA warns that prolonged contact with used engine oil may cause a number of skin disorders, including cancer! You should make every effort to minimize your exposure to used engine oil. Protective gloves should be worn when changing the oil. Wash your hands and any other exposed skin areas as soon as possible after exposure to used engine oil. Soap and water, or waterless hand cleaner should be used.
Disconnect the negative battery cable.
Firmly apply the parking brake and block the rear wheels.
Raise and support the front of the vehicle on jackstands.
Drain the engine oil.
If necessary for additional clearance, remove the center beam.
Fig. 1: On most models, it will be necessary to remove the center beam to access the oil pan
Disconnect the exhaust pipe from the exhaust manifold(s), then position it aside or remove it from the vehicle.
Fig. 2: After disconnecting the exhaust pipe from the manifold, the bracket securing the pipe to the engine block should be removed. The pipe can now be positioned aside
If equipped with flywheel dust shield, it may be necessary to remove it for access.
Fig. 3: The dust shield is secured by several small bolts
Fig. 4: The dust shield may require some maneuvering to remove. Be careful not to damage it
If equipped, disconnect the breather hose from the oil pan.
Fig. 5: If equipped, the breather hose must be disconnected from the oil pan
![https://www.2carpros.com/forum/automotive_pictures/181498_pic1_3.jpg](https://www.2carpros.com/forum/automotive_pictures/181498_pic1_3.jpg)
Fig. 6: After its attaching bolts are removed, the oil pan can be removed from the engine. Never pry on the pan to get it loose
Remove and discard the old gasket.
![https://www.2carpros.com/forum/automotive_pictures/181498_pic2_1.jpg](https://www.2carpros.com/forum/automotive_pictures/181498_pic2_1.jpg)
Fig. 7: The gasket must always be replaced
To install:
![https://www.2carpros.com/forum/automotive_pictures/181498_pic3_4.jpg](https://www.2carpros.com/forum/automotive_pictures/181498_pic3_4.jpg)
8.If equipped, disconnect the breather hose from the oil pan.
![https://www.2carpros.com/forum/automotive_pictures/181498_pic4_3.jpg](https://www.2carpros.com/forum/automotive_pictures/181498_pic4_3.jpg)
![https://www.2carpros.com/forum/automotive_pictures/181498_pic_5_2.jpg](https://www.2carpros.com/forum/automotive_pictures/181498_pic_5_2.jpg)
9.[Remove the oil pan nuts/bolts (in a crisscross pattern) and the oil pan. If necessary, use a mallet to tap the corners of the oil pan. DO NOT pry on the pan to get it loose.
img]
10.Remove and discard the old gasket.
![https://www.2carpros.com/forum/automotive_pictures/181498_pic6_2.jpg](https://www.2carpros.com/forum/automotive_pictures/181498_pic6_2.jpg)
Thursday, December 8th, 2016 AT 12:53 PM
(Merged)
