1992 Honda Accord Fuel consumption
LENDVAI
  • 1992 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 170,000 MILES
It seems that after the last timing belt change the fuel consumption suddenly ecxeeded approx. 1 litre more. Timing is OK, Check engine lamp doesnt light. Sensors are OK, as for their resistance (IAC, TDC, CYL, CRANK ANGLE, IAT, ignition control unit, injectors). Ignition timing is checked, it's 15 degrees precisely. Idle speed is adjusted as it's described in the manual, it's 750rpm. I've changed the air filter, fuel filter, spark plugs. There is a momentary rough running after cold start, and some vibration on idle sometimes. Vacuum gauges are intact.
Wednesday, December 24th, 2008 AT 6:09 AM
BRUCE HUNT
  • 3,754 POSTS
You and I both know that the only thing that has changed is the timing belt, but that did affect the timing. I might suggest moving the timing a degree or two either way to see if that improves things.
Wednesday, December 24th, 2008 AT 9:13 AM
