1992 Honda Accord Dashboard Lights
LOLSTER
  • 1992 HONDA ACCORD
  • 6 CYL
  • FWD
  • 105,000 MILES
My Honda's Stop/brake light came on along with the brake lamp and then ABS and now the Sport light is stuck on after I accidently knocked it.
All within a short space of time.
Thursday, June 5th, 2008 AT 2:54 PM
KHLOW2008
  • 41,814 POSTS
Hi Lolster,
At the gear shift there is a switch, press and see if the S light goes away. If not you have a broken switch and need to replace the gear shift.
As for the brake failure indicator. Check for blown brake bulbs.
The ABS light would come on if the brake master cylinder fluid level is low or the handbrake is not fully released. Check the fluid level first.
Friday, June 6th, 2008 AT 7:18 AM
