1990 Honda Accord Car overheating at idle
MARIKA
  • 1990 HONDA ACCORD
  • 4 CYL
  • MANUAL
  • 200,000 MILES
I have a 1990 Honda Accord with a ton of miles. Lately when I stop at a light the temp will rise to almost H. I am having to add coolant almost daily, but I have never seen any leaks or puddles of coolant, nor does the car steam as if there is a leak when it starts to run hot. I have seen and heard the engine fan running. The A/C doesn't work, so that fan never runs. Any suggestions? Thanks!
Monday, August 10th, 2009 AT 8:53 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Check oil look normal or like a chocolate malt? Does white smoke come from exhaust in morning start up?
Let me know
Thanks for donate
Monday, August 10th, 2009 AT 1:38 PM
MARIKA
The oil looks normal and there is no white smoke.
Monday, August 10th, 2009 AT 1:45 PM
DOCFIXIT
  • 18,828 POSTS
Have you replaced thermostat? It maybe not opening all the way. Has system been flushed in last couple years? Also have radiator cap checked if it can't hold pressure coolant will boil off.
Monday, August 10th, 2009 AT 1:49 PM
MARIKA
None of those things have been done. We'll start with the thermostat and rad cap. Thank you!
Monday, August 10th, 2009 AT 2:16 PM
DOCFIXIT
  • 18,828 POSTS
O.K.
Keep me posted
Monday, August 10th, 2009 AT 2:22 PM
