Heater blowing cold air, transmission not shifting
HARMONY827
  • 2002 KIA SPECTRA
  • 177,000 MILES
Okay, so I noticed my transmission had been changing gears a little rough last couple days. Well this morning it stopped changing all together and I had to drive home in first gear. Also, my heater started blowing cold air this morning and I had smoke coming from under the hood. When I stopped the car and looked under the hood I saw the antifreeze was all over my battery and other stuff in that right corner. So the smoke was actually my hot antifreeze blowing out from the radiator or something.
Monday, January 7th, 2019 AT 6:34 AM
  • 108,407 POSTS
If you lost coolant, that explains why the heater stopped working. First, locate the leak, repair it, and refill the coolant.
https://www.2carpros.com/articles/car-is-leaking-coolant
Now, have any of the lights come on indicating the engine was overheating? If it was hot enough, that may be related with the transmission issue. If the check engine light was staying on when the engine was running, there should be trouble codes stored in the computer identifying where the problem was coming from. With that in mind, you should scan the computer. Here is a quick video showing how it is done:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but often times a parts store will lend or rent one for you to use. They will also scan it for free, but it doesn't sound safe to drive.
Let me know if this helps and what you find.
Monday, January 7th, 2019 AT 6:59 PM
HARMONY827
My husband ended up changing a belt of some kind. Everything is good now.
Monday, January 7th, 2019 AT 10:30 PM
  • 108,407 POSTS
Welcome back:
Glad you got it fixed. Could you let me know what belt it was? I'm interested in knowing.
Thanks,
Tuesday, January 8th, 2019 AT 7:35 PM
HARMONY827
I honestly don't know, but I will ask my husband.
Wednesday, January 9th, 2019 AT 12:41 PM
  • 108,407 POSTS
If you could, I would appreciate it. It may help another person with the same problem.
Wednesday, January 9th, 2019 AT 7:36 PM
HARMONY827
It was the belt that goes on the alternator and water pump.
Wednesday, January 9th, 2019 AT 7:54 PM
  • 108,407 POSTS
Now that makes sense. The water pump not turning explains the heating issues, shifting issues (because of engine temperatures) and the smoke.
Thanks for letting me know. I appreciate it.
Wednesday, January 9th, 2019 AT 9:14 PM
