(1) The van going into limp mode.
(2) The steering getting tight.
(3) The gear shift getting tight to shift.
Friday, April 26th, 2019 AT 7:19 AM
KEN L
MASTER CERTIFIED MECHANIC
This is common and 9 times out of 10 it is caused by a dirty throttle bore causing the correlation to be lost between the throttle actuator and PCM. here is a guide that will help you fix it:
