HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
GMC
Yukon
Ignition
Firing Order
1998 GMC Yukon Firing Sequence
COCO4COCONUTT
MEMBER
1998 GMC YUKON
V8
4WD
AUTOMATIC
130,000 MILES
I need to know the firing sequence for my distributor.
Friday, March 28th, 2008 AT 6:32 PM
MECHANIC
Its 18436572 CC or C remove the distributor cap and observe the rotor rotation while engine is being crank over then follow the firing order-
Software is under maintenance cannot give you a picture-maybe later on-
SPONSORED LINKS
Friday, March 28th, 2008 AT 6:40 PM
Please
login
or
register
to post a reply.
Related Firing Order Content
97 Gmc Yukon: How To Adjust The Timing
1997 Gmc Yukon Sport, 198,000 Miles. How Do I Adjust The Timing?
Asked by
tayalex1978
1997
GMC YUKON
1999 Gmc Yukon No Spark To Plugs
Power To Coil And No Spark To Plugs, Installed New Distributor, Problem Was Only Once In A While At The Begining Now No Spark At All
Asked by
colebank
1999
GMC YUKON
1999 Gmc Yukon Distributor Position
I Put Head Gaskets On This Truck. When I Put Everything Back Together, It Would Not Crank Because The Time Is Off Because The Position I Put...
Asked by
barbara1963
1999
GMC YUKON
1999 Gmc Yukon Timing
I Replaced Intake Gasket And Now Timing Is Off. How Do I Time This Vehicle?
Asked by
free2rok1975
1 ANSWER
1999
GMC YUKON
SPONSORED LINKS
Spark Plug Replacement Ford Escape V6 3.0L
Spark Plug Replacement Toyota Tacoma
Intermittent Misfire
Online car repair manuals
