1995 GMC Yukon Blown 4WD Fuse
OLDYUKE95
  • 1995 GMC YUKON
  • V8
  • 4WD
  • 102,000 MILES
System was working fine, then I attempted to engage the 4WD and nothing happened. I checked and found that the fuse for the 4WD was blown. I replaced it and tried again to engage the system. As soon as the lever was pulled, I could hear the fuse blow. We had recently had a large snowfall, with 2-3 foot drifts crossing some roads. I busted through several of these deep drifts, so I thought that I might have knocked a wire, or damaged a plug. There was no visible damage to any wiring, or the plugs. There is obviously something causing a short, but it seems odd that it would work, then within a matter of hours simply stop. Switch, relay? I really don't want to just throw parts at it, anyone ever deal with this before?
Wednesday, January 28th, 2009 AT 12:33 PM
  • 108,517 POSTS
Hi:
Unplug the wiring to the 4wd actuator on the transfer case and see if the fuse blows when you turn the switch. If it doesn't, I feel the actuator itself may be the problem.
Let me know what you find.
Wednesday, January 28th, 2009 AT 5:29 PM
OLDYUKE95
Disconnected actuator and tested, fuse did not blow. Replaced part and all works fine now.
Thanks!
Monday, February 9th, 2009 AT 9:08 PM
  • 108,517 POSTS
Hi:
That is good news. The reason I had you disconnect the actuator it to determine if there was a short before the power got there. I'm glad it's fixed.
Tuesday, February 10th, 2009 AT 11:43 AM
