Fuel pump relay replacement
DMAIR
  • 1998 GMC SIERRA
  • V8
  • 4WD
  • 200,000 MILES
I have to remove the fuel pump relay and bypass it to get the fuel pump running. Once the truck starts I can replace the relay and drive. Any ideas
Thank you
Doug
Do you
have the same problem?
Saturday, January 23rd, 2010 AT 3:03 PM
Sounds like the computer control of the relay is defective-when you jump start the relay -you prime the system for 2secs when it fires up-what powers it after the 2secs is the fuel pump/oil pressure sending unit.
https://www.2carpros.com/forum/automotive_pictures/12900_oil_sending_unit_and_fuel_pump_circuit_100.gif
Saturday, January 23rd, 2010 AT 4:14 PM
DMAIR
Thats does make a lot of sense. Thanks so much for your quick response.
Doug
Saturday, January 23rd, 2010 AT 7:55 PM
