Fuel smell
MORO
  • 1997 MERCURY VILLAGER
  • 6 CYL
  • 17,500 MILES
Smell gas coming through through vents especially with AC running. Smell also on various occasion while standing outside van. Seems to be coming from under hood.
Monday, July 2nd, 2018 AT 2:23 PM
AL514
  • 4,214 POSTS
Hello, have you looked for any obvious fuel leaks under the hood, fuel injectors, fuel lines? If the smell if that bad you should be able to see wet lines while the car is running and fuel is under pressure in the lines. Leaking fuel can be extremely hazardous under the hood. I would make a very good visual inspection, fuel and a hot engine are not a good combination.
Monday, July 2nd, 2018 AT 2:43 PM
