Cylinder 6 misfire FPC mod. Circuit and IAC valve voltage low.
Saturday, December 7th, 2019 AT 3:46 PM
KEN L
MASTER CERTIFIED MECHANIC
Can I ask how the engine running? Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response. Have you done a tune up recently? Lets fix the misfire to see if the IAC code goes away. If the misfire is constant let do a compression test to see if the engine is okay.
