I try to squeeze the pistons in, the other one wants to come out?
MARK CAVINEE
  • 2010 FORD F-150
  • 100,000 MILES
When I try to squeeze the pistons in, the other one wants to come out. They don't both go in together. I can still get the caliper to install but not as easily as the other side. Is this, okay? Thanks
Wednesday, August 31st, 2022 AT 5:48 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,542 POSTS
As long as they are on you should be fine, I always do one side at a time to avoid this problem, also or you can stick a block of wood in the opposite caliper you are trying to reset. This is normal for the system.
Wednesday, August 31st, 2022 AT 10:45 AM
