2002 Ford Windstar no cold air
JEAN215
  • 2002 FORD WINDSTAR
  • 6 CYL
  • 128,967 MILES
Where can I find the clutch cycling switch or a pressure switch for my a/c
Do you
have the same problem?
Friday, July 17th, 2009 AT 1:19 PM
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_ford_windstar_1.jpg
Your owners manual should give you the location of fuses and relays. There could be other issues, maybe your low on refrigerant?
Check for trouble codes. Also there are two voltage circuits to the ac clutch relay, switch side and coil side of relay. The computer grounds the coil side of clutch relay in order to energize. If the computer isn't grounding the relay, maybe a trouble code will point you in the right direction.
Friday, July 17th, 2009 AT 2:12 PM
