HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Windstar
Engine
Symptoms
Hesitate
SPONSORED LINKS
1999 Ford Windstar engine performance
TITAJOSE89
MEMBER
1999 FORD WINDSTAR
6 CYL
FWD
AUTOMATIC
91,000 MILES
Engine hesitate, misses while on park, runs great when the arpm ar rised. What can cost this?
Saturday, February 6th, 2010 AT 2:23 PM
MECHANIC
Has the check engine light come on? When was the last tune up? Have you checked for vacuum leaks?
SPONSORED LINKS
Saturday, February 6th, 2010 AT 10:25 PM
TITAJOSE89
MEMBER
Yes, check engine light come on. New tune-up. New intake manifold. Will check again for vacuum leaks.
Thank you joe
Monday, February 8th, 2010 AT 7:22 PM
MECHANIC
Also, check the egr valve.
Tuesday, February 9th, 2010 AT 12:56 AM
Please
login
or
register
to post a reply.
Related Engine Hesitate Content
My 2002 Windstar Is Making A Noise When The Rpm's Are...
It's My Wife's And I Drove It Today. When It Gears Down On A Hill, There Is A Noise, Sounded Like A Diesel Motor, That Clacking Sort Of...
Asked by
Kids Too Hot
2002
FORD WINDSTAR
VIDEO
Vacuum Leak Test and Repair
Instructional repair video
GUIDE
Hesitation
An engine hesitation is an interruption of continuous power during acceleration. When a engine is hesitating it will cause the car to lunge or surge which will cause a...
Windstar Hesitation/stumble 800/1100 Rpm
My 95 Windstar Has A Dead Spot/ Hesitation From 800/1100 Rpm. I Have Changed Crank And Cam Position Sensors. Air Idle Motor Throttle...
Asked by
trashman36
1995
FORD WINDSTAR
2000 Ford Windstar Periodic Hesitation When Going...
Periodically My Van Will Hesitate When Changing From 1 Gear To Another. Mostly When I Start Pressing Gas After Stopping At A Red Light
Asked by
Allen Mills
2000
FORD WINDSTAR
2002 Ford Windstar Van Hesitation
In The Past Week, My Van Has Been Experiencing Hesitation/lunging. I Notice It Most Around 65 Mph, But It Has Happened Less Often At Lower...
Asked by
srbarabs
1 ANSWER
2002
FORD WINDSTAR
Hesitation
I Have A 2002 Ford Windstar Sel >213,000 Miles That Is Starting To Hesitate/miss When Going Up A Slight Grade; All Speeds And Even In Cruse...
Asked by
Tuckerk
1 ANSWER
2002
FORD WINDSTAR
VIEW MORE
SPONSORED LINKS
Vacuum Leak
Mass Air Flow Sensor Clean Toyota
Online car repair manuals
