1999 Ford Windstar
OLD TIMER
  • 1999 FORD WINDSTAR
  • 6 CYL
  • FWD
  • 138,000 MILES
I have a 1999 Ford Windstar w/138,000 miles A/T Transmission. The problem that I'am having is it idles high when you first start it than it idles real low. The RMP's jump up and down between 0 and 500 before it stalls. I had it put on a scope by a local parts store. They told me the code for a EGR valve came up to start w/ that so I did. Nothing changed. I really don't know whats wrong w/ it. I thinking about taking it in to be fixed but if it is a easy fix I will probably do it myself. Thank you for your time and your answer.
Saturday, December 29th, 2007 AT 6:00 PM
BMRFIXIT
  • 19,053 POSTS
Check intake manifold for vacuum leak
check idle air valve
was the EGR stuck open?
Saturday, December 29th, 2007 AT 10:31 PM
