1996 Ford Thunderbird over heating
BADAZ
  • 1996 FORD THUNDERBIRD
  • V8
  • 114,000 MILES
I recently changed the intake manifold gasket and was running ok until the engine started to overheat. I barely made it to the gas station and could not start it anymore. I checked the spark plugs and found sighns of water on the spark plug. Would there still be a problem with the intake manifold gasket or could there be a problem with something else? How would I know?
Tuesday, August 5th, 2008 AT 9:28 PM
  • 31,937 POSTS
Hi there,
If you have water in the engine I would be checking the manifold gasket for faulty water cross over sealing or a defective or incorrect gasket. I would also have a head check done just to eliminate a head gasket problem as well.
Mark (mhpautos)
Wednesday, August 6th, 2008 AT 7:37 AM
