Air cabin filter replacement instructions?
TERESA BULT
  • 2011 FORD TAURUS
  • 100,000 MILES
Heater blower blowing on high barely anything coming out.
Thursday, January 12th, 2017 AT 3:24 PM
CJ MEDEVAC
  • 11,005 POSTS
You do mean airflow is barely coming out? I would change the air cabin filter here is a guide to help walk you through the steps with instructions below to help you with your car.
https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter
Thursday, January 12th, 2017 AT 6:27 PM
TERESA BULT
You can hear the difference, but not sure about airflow it is barely coming out on high.
Friday, January 13th, 2017 AT 1:27 AM
SATURNTECH9
  • 30,869 POSTS
Have you checked to see if the cabin air filter is plugged up from not being changed in a really long time?
Friday, January 13th, 2017 AT 7:44 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,408 POSTS
It sounds like it could be a blend door actuator has gone bad. Does it sounds like the blower is working normally but no air is coming out?
Best, Ken
Friday, January 13th, 2017 AT 10:31 PM
SATURNTECH9
  • 30,869 POSTS
When you change the different air positions does the air come out full speed in any of the positions?Try removing the cabin air filter and closing the cabin air filter door and see if the air flow improves.
Saturday, January 14th, 2017 AT 6:55 AM
SATURNTECH9
  • 30,869 POSTS
I posted the instructions and diagram for the pollen filter removal. Just make sure you pay attention to which way the arrow on the pollen filter is going. So when you put one back in you know the new one is installed correctly.
Saturday, January 14th, 2017 AT 7:03 AM
GUTMANN1
  • 2006 FORD TAURUS
Location and way to replace the cabin air filter
Tuesday, June 22nd, 2021 AT 11:21 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Remove the right side cowl vent screen.
Remove the screws and the water shield.
Remove the pollen filter.
To install filter, reverse removal procedure.
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_387.jpg
good luck
CYCLONE701
  • 2005 FORD TAURUS
  • 6 CYL
  • FWD
  • 60,000 MILES
How to change cabin air filter
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_05tauruscabin4_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_05tauruscabin5_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_05tauruscabin6_1.jpg
JOHN MARKS
  • 2003 FORD TAURUS
  • 130,000 MILES
Where is the cabin filter?
STEVE W.
  • 13,593 POSTS
If it has one (LX trim level didn't) it is outside the cabin under the cowl trim piece at the base of the windshield on the passenger side. You remove the clips and gently remove the rubber seal, then the screws. Under that you will find a water shield, remove it and the filter is under it.
LEWLAMB
  • 2002 FORD TAURUS
Location of cabin air filter
BMRFIXIT
  • 19,053 POSTS
Under hood right side
Removal & Installation
open hood
Remove the right side cowl vent screen..
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_433.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_216.jpg
TRLH4
  • 2002 FORD TAURUS
  • 6 CYL
  • 104,000 MILES
My manual says the cabin air filter is located just in front of the windshield under the cowl grille. Is this on the dash by the windshield or under the hool by the windshield. I took off what I thought was the cowl grille on the dash but could not find it.
BMRFIXIT
  • 19,053 POSTS
(2000-2007)
Open hood
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_440.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_218.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic3_103.jpg
TODDBWEAVER
  • 2002 FORD TAURUS
Just want to replace the cabin air filter, but I'm unable to locate it yet. Is it possible it doesn't have one? Thanks Todd
TAURUSWHEEL
  • 718 POSTS
Pop the hood, look at the passenger-side cowl, there should be some clips. Pop these off, drop down the housing you should be able to see the filter. I sugggest buying yourself a Chilton, or some such, type of book for your model year. It has a lot of info such as what you're looking for, relatively not much $$$$ also, no be-all end-all but some good info regardless.
TODDBWEAVER
Thanks for the info, I'll pick one up today. I've used them before.
