2000 Ford Taurus panel lights
PAPY000
  • 2000 FORD TAURUS
Electrical problem
2000 Ford Taurus 6 cyl Front Wheel Drive
panel lights wont come on were is fuse located to repair
Sunday, September 19th, 2010 AT 7:18 AM
  • 108,269 POSTS
Actually, power for the panal lights come on through the headlight switch. I don't believe there is a seperate fuse for them. Have you checked behind the cluster to make sure everything is tight? Same with the headlight switch?
Sunday, September 19th, 2010 AT 12:47 PM
GIOVANNI29
Go under where your brake and gas paddle are the fuse box is located to the left of it
Sunday, September 19th, 2010 AT 1:16 PM
  • 108,269 POSTS
That is correct. Let me know if you find it.
Monday, September 20th, 2010 AT 10:40 PM
