Serpentine belt has some cracks in it and needs to be replaced?
STRMTHDRUM
  • 1995 FORD TAURUS
  • 6 CYL
  • FWD
  • 100,000 MILES
My serpentine belt has some cracks in it and needs to be replaced. I already have the part but don't know how to replace it.
Tuesday, March 24th, 2009 AT 4:52 PM
BILLYMAC
  • 2,204 POSTS
https://www.2carpros.com/forum/automotive_pictures/300339_Ford_Taurus_95F15151_1.jpg
hi belt is fairly easy to change you may want to borrow a belt tensioner release the tension remove the belt use this diagram to re route new one make sure it is on all the grooves in all the pulleys release tension and you are done takes about ten mins thanks billymac
Tuesday, June 29th, 2021 AT 10:24 AM
