MY SCANNER ALLOWS ME TO SEE THE DATA STREAM. THE TWO SENSORS UPSTREAM SHOW RICH/LEAN SWITCHES AND VOLTAGE CHANGES. THE DOWN STREAM SENSOR (AFTER THE CAT) SHOWS "NO DATA" BUT THERE ARE NO CODES SET. ENGINE IDLES ROUGH, IT RUNS FINE UP TO 50 MPH THEN MISFIRES BAD AGAIN. NEW- MAS-TPS-COIL-PLUGS-FUEL FILTER- ANYONE GOT ANY IDEAS. THANKS.
SPONSORED LINKS
Tuesday, February 23rd, 2010 AT 12:25 PM
MECHANIC
Have you checked the downstream sensors?
Monday, March 1st, 2010 AT 10:54 PM
HILLHEAD
MEMBER
I THINK THE ONLY OXYGEN SENSOR DOWNSTREAM IS THE ONE THAT SHOWS "NO DATA" BUT SETS NO CODES. THE TRUCK RUNS LIKE CRAP---
SPONSORED LINKS
Tuesday, March 2nd, 2010 AT 5:30 PM
MECHANIC
I would check it to see if that is where the problem is. It may not be setting the light for some reason.
Wednesday, March 3rd, 2010 AT 6:40 AM
HILLHEAD
MEMBER
THANKS.I WILL REPLACE THE SENSOR. HOPE IT SOLVES THE PROBLEM.
Wednesday, March 3rd, 2010 AT 8:57 AM
MECHANIC
You can check the resistance in the old one to see if it is bad, or maybe one or the parts stores will do it for you.
Let me know if you have questions.
SPONSORED LINKS
Wednesday, March 3rd, 2010 AT 10:05 AM
HILLHEAD
MEMBER
I REPLACEDTHE DOWNSTREAM OXYGEN SENSOR AND IT MADE NO DIFFERENCE. IT STILL SHOWS "NO DATA" ON MY SCANNER. ALSO IF YOU UNPLUG THE IAC OR THE MAS IT DOES NOT CHANGE THE WAY THE ENGINE IDLES, WHICH IS CRAPPY. NO CODES SET.
