1998 V6 INTAKE MANIFOLD
JIMVANDYUSA
  • 1998 FORD RANGER
I HAVE A 1998 FORD RANGER 4X4, V6. I HAD ONE OF THE METAL TUBES ON THE TOP OF THE INTAKE MANIFOLD BREAK OFF. THERE ARE TWO TUBES. THEY HAVE WATER LINES COMING FROM THE HEATER HOSES. I GUESS IT IS FOR CIRCULATING WATER THROUGH THE MANIFOLD. MY PROBLEM IS I DON'T KNOW HOW TO FIX THE PROBLEM. IT LOOKS LIKE THE TUBES WERE PRESSED FITTED INTO THE ALUMINUM MANIFOLD. I NEED SOME HELP.
Saturday, September 29th, 2007 AT 11:27 PM
MERLIN2021
  • 17,251 POSTS
At this point you may need to drill and tap, then screw in a piece of tubing! Connect with ruber tube and clamps, don't forget the teflon thread sealer!
Sunday, September 30th, 2007 AT 7:47 AM
