HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Focus
Drivetrain
Transmission
Fluid
2007 Ford Focus transmission fluid
GREASE-MONKEY-13
MEMBER
2007 FORD FOCUS
4 CYL
2WD
AUTOMATIC
27,000 MILES
How do I add more transmission fliud to my car?
Wednesday, June 23rd, 2010 AT 10:18 PM
MECHANIC
Warm the engine up and leave it running find the dipstick for the tranny check the level if its low add a lil at a time till it comes up on the full mark
Make sure you use MERCON V
SPONSORED LINKS
Wednesday, June 23rd, 2010 AT 11:40 PM
Please
login
or
register
to post a reply.
Related Transmission Fluid Content
Transmission
Oil Was Put In The Transmission By Accident, Is It Okay To Drive It?
Asked by
Iola
2007
FORD FOCUS
I Need To Find Where To Put My Transmission Fluid.
I Need To Find Gear Oil In Manual Transmission?
Asked by
falisha
2001
FORD FOCUS
2006 Ford Focus Changing Atf
What Is Required To Change The Atf On A Focus? I Read A Post On Ehow That Said To Just Disconnect The Tube That Goes Into The Radiator...
Asked by
andym3122
1 ANSWER
2006
FORD FOCUS
2002 Ford Focus Transmission Problem / Overdrive...
When Driving My Car In Overdrive It Tends To "kick Out Of Gear" But When I Turn Overdrive Off It Does Fine. What Is The Problem? And Can I...
Asked by
acarico
1 ANSWER
2002
FORD FOCUS
2007 Ford Focus Sound In Reverse
The Car Makes A Low Pitched Squealing Sound, But Only When Moving In Reverse. It Almost Sounds As If Something Isn't Lubed Properly, Or...
Asked by
tehrolo
2007
FORD FOCUS
VIEW MORE
SPONSORED LINKS
Transmission Service Ford F-150 2011-2014
Transmission Drain and Refill
Service a Transmission Ford F-150
Online car repair manuals
