Rear brake adjust diagram?
AANOTICE
  • 2005 FORD FOCUS
  • 4 CYL
  • FWD
  • 20,000 MILES
How do I adjust the rear brake on a Ford fucus
Sunday, April 6th, 2008 AT 11:49 AM
MIKE H R
  • 3,094 POSTS
If your car can have disc brakes there is no adjustment. Here is a video that show the job being done and the adjustment after replacing the shoes.
https://youtu.be/1j7qDoi1LP0
Did you put new brakes on? Here is a guide that helps with low brake pedal as well
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Monday, March 15th, 2021 AT 7:41 PM
MERLIN2021
  • 17,251 POSTS
https://www.2carpros.com/forum/automotive_pictures/62217_Brake_adja_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_Brake_adjd_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_Brake_adjb_1.jpg
What this means is use a brake adjusting gauge set it to the drums inner diameter, then fit it over the shoes and pull shoes apart to get a snug fitting drum, then follow the directions above...if you dont have the tool, trial and error will have to do! Use a flat blade screwdriver to help closing the shoes together if you need to...Pry at "3" This will push the ratchet mech away and allow the shoes to close up...
