HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Focus
Drivetrain
Transfer Case
2002 Ford Focus
REDNECK1861
MEMBER
2002 FORD FOCUS
Engine Mechanical problem
2002 Ford Focus 4 cyl Two Wheel Drive Automatic
how to set the timing
Monday, May 31st, 2010 AT 8:52 AM
OBXAUTOMEDIC
MECHANIC
Ok, are you replacing the Timing Components or trying to set timing like on older Distributor Engines.
If trying to set timing then you cannot it is Electronically Controlled by the Cam and/or Crank Sensor.
If looking for Setting Timing Marks then check out link below...
https://www.2carpros.com/car_repair_information/year/2002/make/ford/model/focus/2002_ford_focus_timing_belt_diagram_marks.htm
SPONSORED LINKS
Monday, May 31st, 2010 AT 9:05 AM
Please
login
or
register
to post a reply.
Related Transfer Case Content
2003 Ford Focus My Ford Focus 2003 Shakes At Around...
Shakes Or Wobbles Problem 2003 Ford Focus 4 Cyl Front Wheel Drive Automatic 100k Miles My Focus 2003 Shakes At A Speed Of Around 65-70...
Asked by
kjensen77406
2003
FORD FOCUS
1996 Ford Focus
Engine Mechanical Problem 1996 Ford Focus 4 Cyl Front Wheel Drive Automatic I A Machanic In Trinidad Doing A...
Asked by
shamauto
1996
FORD FOCUS
2001 Ford Focus Eractic Idling
Engine Performance Problem 2001 Ford Focus 4 Cyl Front Wheel Drive Automatic My Focus When I Stop Idles Eractically, Especially...
Asked by
weetottie32
1 ANSWER
2001
FORD FOCUS
2000 Ford Focus Freon
2000 Ford Focus 4 Cyl Front Wheel Drive 131000 Miles Where Is The Line To Put Freon In?
Asked by
lapullen
1 ANSWER
2000
FORD FOCUS
2002 Ford Focus Noise
Sounds Like A Pat Pat Pat Coming From One Of My Tires Almost Like I Was Getting A Flat When I Lightly Step On The Brakes Noise Goes Away....
Asked by
claudialove
2002
FORD FOCUS
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
Transmission Mount Replacement - RWD Cars
Transmission Drain and Refill
Online car repair manuals
