HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Engine
Starter
Relay
SPONSORED LINKS
Starter relay fuse burns out when ignition is engaged
PEPSIMAN
MEMBER
FORD F-150
2000 Ford F150 pickup 4wd 125,000 miles is blowing 15 amp breaker when key is turned, wont even engage starter.
Friday, September 7th, 2007 AT 7:35 PM
MERLIN2021
MECHANIC
Check the ignition wire to the solinoid I think its LTBLUE/RedST Hot is grounding someplace!
SPONSORED LINKS
Friday, September 7th, 2007 AT 8:34 PM
PEPSIMAN
MEMBER
Groung wire to starter had wiggled loose and was grounding on frame.
Sunday, September 9th, 2007 AT 4:49 AM
Please
login
or
register
to post a reply.
Related Starter Relay Content
1983 Ford F150 Starter Relay
Electrical Problem 1983 Ford F150 6 Cyl Two Wheel Drive Automatic Back In Feb. We Had Someone Help Us Jump Our Battery, But They Blew...
Asked by
bdfgrl
1983
FORD F-150
1988 Ford F150 Starter Relay On Fender
Need Awiring Diagram
Asked by
billbell
1988
FORD F-150
2000 Ford F150 Starter Issues
I'm Lost. I First Began Having Issues With The Truck Not Starting. I Would Get One Click And Nothing. Battery Tested And Is Fine....
Asked by
ffelrod
2000
FORD F-150
1994 Ford F150 New Starter Will Not Spin Engine Over
I Recently Replaced A Sticky Starter With A New One And Now All It Will Do Is Click, The Battery Shows 12.6 Volts, Cleaned And Retightened...
Asked by
brad knight
1 ANSWER
1994
FORD F-150
Starter Replacement?
How Many Bolts Do I Need To Take Off To Remove The Starter?
Asked by
jamesdavis52
31 IMAGES
2004
FORD F-150
VIEW MORE
SPONSORED LINKS
Starter Replacement
Starter Motor Replacement
How to Use a Test Light
Online car repair manuals
