1999 Ford F-150 starting
PAULWILLIAMS555
  • 1999 FORD F-150
  • V8
  • 188,156 MILES
I am so confused I cannot get my 99 F150 to start. I have changed the starter, battery is good. The starter does not seem to be getting power to start the truck. Have even tried to bypass the fuse-able link and it still does not start.
Saturday, February 20th, 2010 AT 8:59 AM
  • 108,310 POSTS
Have you replaced the starter relay? Have you checked for power to the relay or the starter? When you turn the key on, do the dash lights come on?
Monday, February 22nd, 2010 AT 9:39 PM
PAULWILLIAMS555
It starts when I jump the relay. It will start occasionally when it sits for 3 hrs or longer. Once it starts and I shut it off, it will not start again unless I jump the relay. It is a 99 F150 2wd with a 4.6 triton V8
Thursday, February 25th, 2010 AT 5:58 PM
  • 108,310 POSTS
Have you tried replacing the relay?
Friday, February 26th, 2010 AT 12:33 PM
