Blower fan just shut off
TRITON_DC
  • 1998 FORD F-150
My blower fan stopped working all at once I checked the fuses and both are good, I checked for power with a volt meter on the fan motor with the switch on high no power, I check at the switch and no power. Any suggestion please.
Sunday, July 20th, 2008 AT 11:53 AM
MERLIN2021
  • 17,251 POSTS
Usually turns out to be the resistor, but where you have no power to the switch, check the blower relay behind the center of the instrument panel, and if that's good, check the grounds under the front passenger kick panel...
https://www.2carpros.com/forum/automotive_pictures/62217_Blower_Relay_1.jpg
Look for #22
Monday, April 19th, 2021 AT 11:15 AM
TRITON_DC
That was it the blower relay is melted. Is that a part I need to order from ford or any part store will do?
Thank you
merlin2021
MERLIN2021
  • 17,251 POSTS
Any parts store will do.
TRITON_DC
All good replaced the relay and its all fixed.
