1997 Ford F-150 Water leak from rear of engine!
JSAUSAU
  • 1997 FORD F-150
  • V8
  • 4WD
  • 208,000 MILES
My F-150 truck has this water leak coming from the back of the engine, spraying onto the firewall then down. I can't physically see where its coming from, any ideas?
Thanks,
js
Hello, thank you all for your responses. It is leaking coolant from the rear part of the engine. My coolant is real rusty color?
Thanks,
js
Thursday, October 22nd, 2009 AT 7:59 PM
CRZYDRVR
  • 432 POSTS
Is it water or antifreeze?
Thursday, October 22nd, 2009 AT 9:35 PM
CJ MEDEVAC
  • 11,004 POSTS
Try INSPECTION MIRROR
Friday, October 23rd, 2009 AT 12:53 AM
  • 31,937 POSTS
Hi there,
You will have to get the cooling system pressure tested, this will locate any external leaks, inspect rear of engine and head with a mirror and a good light, check heater hoses, if any hose feels hard or is swollen, replace them, start here.
Mark (mhpautos)
Friday, October 23rd, 2009 AT 9:37 PM
