Heater problem
1989 Ford F150 6 cyl Two Wheel Drive Manual
Hello, I have a 89 Ford F-150. When I use the heater or AC I have a strong gas odor in the cab
Monday, October 20th, 2008 AT 7:41 AM
BROKIN
MEMBER
Mine just started doing this Friday morning going to work wanted to put the window down but it was so cold I didnt
I can smell it when I pop the hood but havent seen anyleaks.
SPONSORED LINKS
Monday, December 8th, 2008 AT 6:53 PM
MECHANIC
Hi:
When you use the heater / ac you have to be getting fumes from the engine compartment. There could be an injector, fuel line, or anything related to the fuel system, but I'm sure you have a leak.
Friday, December 12th, 2008 AT 4:13 PM
BROKIN
MEMBER
Yeah I found it one of the injectors has a leaking O ring I cant wait to fix it lol
Saturday, December 13th, 2008 AT 2:08 PM
MECHANIC
Hi:
They arn't as bad as they look. If you have any trouble, let me know.
