I put in a new starter and seliniod but it just makes a clicking sound
Friday, August 6th, 2010 AT 8:47 PM
MECHANIC
Are all the terminals at the battery clean and tight? Also, check the ground to the engine block. Finally, are you getting 12+ volts to the starter when the key is in the start position?
