HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Electrical
Battery
Replace/Remove
SPONSORED LINKS
2003 Ford Explorer Remove battery
JACKIEGROVER
MEMBER
2003 FORD EXPLORER
Engine problem
2003 Ford Explorer V8 Wheel Drive Type unknown Automatic 82300 miles
How do you remove the battery from a 2003 Ford Explorer, Edd Bau?
Tuesday, February 19th, 2008 AT 5:31 PM
2CARPRO JACK
MECHANIC
Unhook neg cable and then positive cable. Then unbolt the hold down
SPONSORED LINKS
Tuesday, February 19th, 2008 AT 5:33 PM
JACKIEGROVER
MEMBER
I just wanted to thank you for the quick reply, I don't have anyone to ask and your help is so very much appreciated.
Jackie
Tuesday, February 19th, 2008 AT 6:12 PM
2CARPRO JACK
MECHANIC
Youre very welcome
Tuesday, February 19th, 2008 AT 6:30 PM
Please
login
or
register
to post a reply.
Related Battery Replace/Remove Content
2003 Ford Explorer Battery Replacement Issue
Electrical Problem 2003 Ford Explorer 6 Cyl 110000 Miles I Have A 2003 Ford Explorer Sport, Which I Replaced The Battery On...
Asked by
heals822
2003
FORD EXPLORER
VIDEO
Battery Replacement Ford
Instructional repair video
GUIDE
Battery Replacement
Replacing a car battery is easy to do and will take about 20 minutes in most cases, this job can be done using everyday tools. Please wear protective gloves and eyewear when...
Trying To Remove Positive Battery Shield
My Battery Is Dead And I Cannot Get This Shield Off The Battery. I Cannot Find Any Schematics On The Web. The Problem Is The Little...
Asked by
Heather Shillington-Pinkerton
4 IMAGES
2013
FORD EXPLORER
Changing Battery- Ford Explorer
I Changed Battery In Ford Explorer- Now No Power At All?
Asked by
hreich
1 ANSWER
2006
FORD EXPLORER
1997 Ford Explorer Battery Replacement Problem
I Replaced The Battery On My 1997 Ford Explorer L.E. And After Replacing It, The Displays In The Cabin Did Not Reset (i.E; Radio Display...
Asked by
klorster
1 IMAGE
1997
FORD EXPLORER
1998 Ford Explorer Battery Replacement
Unable To Get The Starter To Crank, Have Replaced The Old 65-650ah With A New 65-850ah. Everything Works Fine Except, When I Switch On The...
Asked by
chriswebster4276
1998
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Battery Replacement
How to Replace Battery
Battery Replacement Dodge
Online car repair manuals
