My steering wheel is vibrating at hwy speed, the higher the speed, the worse the vibration. It also vibrates sometimes when I brake. What could be causing this, and should my warranty cover it?
Thanks!
Monday, June 15th, 2009 AT 7:57 PM
MECHANIC
It could be caused by tire ballance or a bent rim. Try rotating the tires to see if it changes. Also, when you use the brakes and it shakes tells me your front brake rotors are warped.
