Engine Mechanical problem
1999 Ford Expedition V8 All Wheel Drive 150000 miles
can rod and mains be rolled in without removing engine
Friday, March 12th, 2010 AT 6:23 PM
MECHANIC
Rod bearing can because you can remove the end cap and tap the piston up to gain access. However, the mains can not. The crank needs removed to do it. To remove it, the engine needs to be out.
