1997 Ford Expedition Low Pressure Recharge location
JDKIGHT71
  • 1997 FORD EXPEDITION
  • V8
  • 4WD
  • 170,000 MILES
Could you please tell me where the low pressure recharge location is to add R134A to my A/C?
Monday, July 5th, 2010 AT 2:03 PM
  • 108,517 POSTS
The low pressure charge port is located on the dryer housing. It is on the left side mounted to the firewall below the power dist panel. It will have a plastic cap that unscrews exposing the port. Make sure to replace the cap after recharging.
NOTE: I don't know what you are using to recharge the system, but on today's recharging tools, it should only fit on the low pressure side. If you make a mistake, put it on the high pressure side, and are using a steel can of freon, it could cause it to burst.
Let me know if you have other questions and be careful.
Wednesday, July 7th, 2010 AT 11:00 PM
