HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
E-Series Van
Engine
Dipstick
Tube
1999 Ford E-Series Van leaky oil dip stick tube
EASTCOAST9
MEMBER
1999 FORD E-SERIES VAN
V8
2WD
AUTOMATIC
42,000 MILES
How can I stop oil from coming out of the dip stick tube, where the dipstick goes in the pan. Thanks
Monday, March 22nd, 2010 AT 2:15 PM
MECHANIC
There is an o-ring at the end of the tube. Remove the tube, clean everything, and replace the o-ring. That should take care of the problem.
Let me know if it helps.
SPONSORED LINKS
Tuesday, May 4th, 2010 AT 8:02 AM
Please
login
or
register
to post a reply.
Related Dipstick Tube Content
1999 Ford E-series Van Iat Reads High
Autotap Scan Tool Indicates Iat To Be 217f To 247f. New Maf/iat Installed, Same. Wiring Checks Out Okay From Maf/iat Module To...
Asked by
wwest40
1999
FORD E-SERIES VAN
1999 Ford E-series Van Computer Code
Service Engine Soon Came On And The Code Was 1507 Don't No What That Is
Asked by
pflesher
1 ANSWER
1999
FORD E-SERIES VAN
Which Part Is It?
Using An Actron Obd Ll Auto Scanner On A 1999 Econoline Van The Code Comes Up P1299, If I'm Reading The Book Corectly, It Falls Between...
Asked by
greenmachine6
1999
FORD E-SERIES VAN
2003 Ford E-series Van How To Determine Timing Chain...
My Van Is Running A Little Rough, And Sounds Like I Got A Piston Or 2 Kissing My Valves. How Do I Determine If I Have A Timing Chain...
Asked by
Clay Cupit
2003
FORD E-SERIES VAN
1997 Ford E-series Van I've Got A Vacuum Hose
Air Conditioning Problem 1997 Ford E-series Van Two Wheel Drive Automatic 27000 Miles I've 1997 Rv On A Ford E-superduty W/ V-10 Auto...
Asked by
datadump
1997
FORD E-SERIES VAN
VIEW MORE
SPONSORED LINKS
Oil Change and Filter Replacement Ford Focus
Oil Change Filter Replacement Subaru
New Car Service
Online car repair manuals
