HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Contour
Electrical
Battery
Jump
2000 Ford Contour
GHANCOMYAN SINGH
MEMBER
2000 FORD CONTOUR
6 CYL
2WD
AUTOMATIC
150,000 MILES
I CHANGE THE ALTERNATOR BUT THE BATTERY ONLY HOLD CHARGE FOR ABOUT 36HRS. AFTER THAT I HAVE TO JUMP START THE CAR AGAIN.
Saturday, January 16th, 2010 AT 6:54 AM
MECHANIC
There's something draining the battery overnite-Do below
SPONSORED LINKS
Saturday, January 16th, 2010 AT 7:06 AM
Please
login
or
register
to post a reply.
Related Battery Jump Content
Is It My Alernator Or Battery? Or Is My Starter...
I Have A 1999 Ford Contour, 4cyl With 76856 Mi. On Odometer. Here Is The Issue I Have Been Having. I Pulled Up To A Gas Station One Night...
Asked by
Palantine
1 ANSWER
FORD CONTOUR
VIDEO
How to Jump Start a Battery
Instructional repair video
GUIDE
Battery Jump Start
A battery jump start is easy to do but can be hazardous if not performed correctly. This guide will show you the do's and don'ts to keep you safe, and get you back on the...
2000 Ford Contour Battery Cable
The Positive Battery Cable Going From The Battery To The Motor Is Got Just Bare Wirethe Outside Coating Has Melted Away The Car Is...
Asked by
prouddaddy425
1 ANSWER
2000
FORD CONTOUR
Replacement Of Car Battery
After Replacing My Car Battery, The Radio Will Not Turn On.
Asked by
B C
2000
FORD CONTOUR
Battery Drain
Electrical Problem 1997 Ford Contour 4 Cyl Front Wheel Drive Automatic My Battery Has Been Draining After 3 Days---i Had My Alternator...
Asked by
Jon24Jai
1997
FORD CONTOUR
Drain Battery
Battery When Charge At 13, 14 Volts. Will Not Stay Charge. Change Post On Battery. Jump Car With Cable, Car Start But After An Hour Or...
Asked by
dora_sigue
1 IMAGE
1998
FORD CONTOUR
VIEW MORE
SPONSORED LINKS
Battery Jump Starter
Battery Replacement Toyota
Online car repair manuals
