HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Contour
Engine
Oxygen Sensor
Replace/Remove
1998 Ford Contour O2 sensor
MISTYKAL
MEMBER
1998 FORD CONTOUR
Engine Mechanical problem
1998 Ford Contour 4 cyl Front Wheel Drive Automatic
i dont know how to replace the o2 sensor
Monday, June 7th, 2010 AT 10:02 PM
MECHANIC
REMOVAL
Remove the engine splash shield.
Disconnect the heated oxygen sensor electrical connector.
Detach the heated oxygen sensor wiring harness from the retaining clip.
Remove the heated oxygen sensor.
INSTALLATION
To install, reverse the removal procedure.
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
SPONSORED LINKS
Monday, June 7th, 2010 AT 10:35 PM
Please
login
or
register
to post a reply.
Related Oxygen Sensor Replace/Remove Content
1998 Ford Contour E Check Failure O2 Sensors
1998 Ford Contour 6 Cyl 128000 Miles My Sons Car Did Not Pass Our E Check, We Have Changed The O2 Sensors(both)and The Check Engine...
Asked by
bud236
1 ANSWER
1998
FORD CONTOUR
VIDEO
Oxygen Sensor Replacement
Instructional repair video
GUIDE
An oxygen or lambda sensor is used to determine the engine exhaust mixture which can then be controlled by the computer. These sensors are equipped with a heater that can...
1998 Ford Contour Se V6 2.5l Dohc
Hello, I Would Like To Get Some Help Before Wasting More Money. The "check Engine Soon" Light Came On And It Gave 7 Codes 5 Pertaining To...
Asked by
tomtina200
1998
FORD CONTOUR
1998 Ford Contour Se 2.5l 24v Dohc Trouble Codes
My Question Is What Do You Guys Thinks Is Wrong With My Car. I Had Code P0133, P0136, Po141, And P0401 They All Are Pertaining To Bank 1...
Asked by
tomtina200
1998
FORD CONTOUR
1998 Ford Contour Se 210,000 Miles 4 Cylinder
My Husband And I Recently Took Our Car To The Mechanic And He Said The Oxygen Sensor Is Bad. My Husband Found One Online To Purchase Under...
Asked by
trazizzle
1998
FORD CONTOUR
How Do You Replace An Oxygen Sensor
Asked by
pickLesMom
1998
FORD CONTOUR
VIEW MORE
SPONSORED LINKS
Oxygen Sensor Replacement Dodge
How to Read Codes Chevrolet
Online car repair manuals
