1998 Ford Contour
RDA1162
  • 1998 FORD CONTOUR
  • 4 CYL
  • FWD
  • 98,000 MILES
I just repaired my timing belt but still won't start so I have to do timing over but the intake screw [bolt ]is now stripped any ideas on how to remove it
Tuesday, November 2nd, 2010 AT 11:53 AM
WRENCHTECH
  • 20,758 POSTS
Do you have the correct special tools and instructions for setting up that belt?
I assume this is a DOHC, vin#3
Tuesday, November 2nd, 2010 AT 12:17 PM
RDA1162
  • 10 POSTS
Yes I have the right tool but the head is stripped and all i'm doing is making it worse what can I do to get it out
Tuesday, November 2nd, 2010 AT 12:40 PM
WRENCHTECH
  • 20,758 POSTS
It can be drilled and tapped and a heli-coil installed but if the hole is already destroyed, it may be too late for that. You may be looking at a new head at this point.
Tuesday, November 2nd, 2010 AT 12:46 PM
