HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Contour
Engine
Symptoms
Not Running
SPONSORED LINKS
1995 Ford Contour turn over but wont start!
DAWANGORE
MEMBER
1995 FORD CONTOUR
1995 Ford Contour Automatic
were is my fuel cap located?
Monday, July 28th, 2008 AT 3:43 PM
KLSHIEL
MECHANIC
Your fuel cap is the cap you take off to put fuel into your car.
SPONSORED LINKS
Monday, July 28th, 2008 AT 3:51 PM
KLSHIEL
MECHANIC
If you meant fuel filter it is a metal canister about 2 inches in diameter and about 4 inches long under the car between the tank and engine.
Monday, July 28th, 2008 AT 3:55 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1995 Ford Contour Car Wont Start
2 Days Ago I Replaced My Dead Battery With A New Battery. It Has Started Fine The Last 2 Days But This Evening Car Wont Start. The Engine Is...
Asked by
kraft84
1995
FORD CONTOUR
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting - Top 3 Easy Steps
Over the past 20 years on 2CarPros we have identified the top three problems that are easily fixed. This can save you a trip to the repair garage or calling a tow truck and...
1995 Ford Contour Starting Problem
I Have A 1995 Ford Contour. For The Past Two Months I Have Had Difficulty Starting It If I Took A Short Trip Before. It Would Take 5 To 10...
Asked by
panamarachel
1995
FORD CONTOUR
95 Contour Checked Everything Still Wont Start
I Have Run Into A Dead End I Have A Motor That Turns Over But For The Life Of Me Will Not Start I Have Checked Fuel And Spark And Getting...
Asked by
installman27
1995
FORD CONTOUR
1995 Ford Contour
1995 Ford Contour Will Not Start. Changed Plugs And Wires Although Spark Seems Dull (not A White Spark More Of A Yellow Spark). Checked...
Asked by
brinkone
1 ANSWER
1995
FORD CONTOUR
Engine Not Running
My Car Has Recently Started Stalling Momentarily And Then Would Continue Running With Loss Of Power Especially When Going Uphill Or When...
Asked by
Freapah
2 IMAGES
1999
FORD CONTOUR
VIEW MORE
SPONSORED LINKS
Not Running - Advanced
Crankshaft Sensor Replacement
Online car repair manuals
